rawlir | -- 09-01-2019 @ 6:51 PM |
Hello, Can anyone point me to a supplier for a 6Volt Period Correct 1947 pickup (100HP V8)Ford battery? Thanks. Rick Rawlings rickr449@gmail.com
MG | -- 09-01-2019 @ 9:22 PM |
Here > http://www.antiqueautobattery.com/batteries/ford/2hf.html And here > https://www.batterycentralmall.com/Batteries/TurboStart/Script/S2HF_R.html
51woodie | -- 09-02-2019 @ 3:34 AM |
Has anyone bought a battery from either of these companies? One of them looks like it is located in an abandoned industrial building (google maps street view) and the other doesn't give a physical address, only a mailing address.
1934 Ford | -- 09-02-2019 @ 9:04 AM |
I've been buying them at Tractor Supply for $79,00 since the price went so high on Optima batteries. 1934 Ford's since 1972 This message was edited by 1934 Ford on 9-2-19 @ 9:05 AM
MG | -- 09-02-2019 @ 11:17 AM |
1934 Ford - More info please on the batteries you buy from Tractor Supply. Are they Group 2LF batteries? Are they 'wet cell'? I have not been able to find the Group 2LF batteries which fit correctly/properly under the floor of my '34. The Group 2HF batteries currently available are too tall to fit properly in a stock '34....
carcrazy | -- 09-02-2019 @ 1:03 PM |
NAPA lists a 6V Battery Part #7244 as an exact fit for a 1947 Ford Pickup. Your local NAPA store may have one in stock or can have it for you in a day or so after you order it. I bought one back in June and the out-the-door price with an old battery core refund was slightly less than $100.
sarahcecelia | -- 09-02-2019 @ 1:13 PM |
Deka makes one. I put it in my 1940 Ford car recently; good battery, $89.00-decent warranty too. Regards, Steve Lee
42guy | -- 09-02-2019 @ 3:15 PM |
I had a NAPA battery and lasted not quite 2 yrs. Switched to Interstate and the one I have now is over 5 yrs. and started right up this year after sitting all winter.
rawlir | -- 09-02-2019 @ 3:28 PM |
Great feedback to all, thanks so much i will follow up and report back......Rick
Pat's 52 | -- 09-03-2019 @ 9:21 AM |
Antique Battery Co. is now Jim's Battery Mfg. Co. It has been bought out by new owners. Phone #800 426-7580. I just ordered a battery for my 52 Ford. I ordered an Optima battery in a Ford script case. It is expensive but I got good life out of my last one. I would probably still be using it but my voltage regulator was set to high and caused it to fail due to over charging. My car is a Dearborn car and I want to keep it original.
1934 Ford | -- 09-03-2019 @ 9:31 AM |
I don't know where you can find a 2L battery since Johnson Controls quit making them. I moved my sedan battery to under the back seat to fit the dual exhausts . In my 35 Pickup I lowered the batter box to take a standard height 6 Volt Battery. I think any Ford V8 with the battery under the hood can use the Tractor Supply battery. I think it says Exide on the sticker. 1934 Ford's since 1972 This message was edited by 1934 Ford on 9-3-19 @ 5:24 PM
37RAGTOPMAN | -- 09-03-2019 @ 10:20 AM |
hi you can try DEKA BATTERY, seems like they have a heavy duty 6 volt battery they give you the measurements www.dekacatalog.com hope this helps. 37 Ragtopman This message was edited by 37RAGTOPMAN on 9-3-19 @ 12:02 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13187 |
