stan white | -- 08-29-2019 @ 12:00 PM |
how do I replace rear window glass on a 34 3 window coupe with roll up glass? This message was edited by stan white on 8-29-19 @ 2:38 PM
37RAGTOPMAN | -- 08-29-2019 @ 1:57 PM |
STAN we need more info so the experts that own 33-34 FORD .can let you know, roll down rear window or fixed rear window,? hope this helps, 37Ragtopman
stan white | -- 08-29-2019 @ 2:36 PM |
From what I understand all 34 Ford 3 window coupes where deluxe models, which would have roll up rear windows.
37RAGTOPMAN | -- 08-29-2019 @ 2:47 PM |
hi Stan SORRY was only trying to help you I did not know,about 3 window coupes, being only deluxe models, I thought it might have had a roll down rear window but was not sure, I think you have to remove the front seat backrest to see how it comes out, maybe the whole seat,? it should be a easy fix, once the back rest is removed, to see how the glass is removed, POST some photo's of what you want to do hope this helps 37RAGTOPMAN
stan white | -- 08-29-2019 @ 3:09 PM |
Thanks for the info. Stan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13177 |
