nubes@bestweb.net | -- 08-18-2019 @ 11:18 AM |
Following Mac VanPelts excellent "ins and out of early Ford transmissions". However, when reassembling the mainshaft, there is too much fore/aft movement,(about 1/8 inch. I installed the 7063 spacer ring, but at the rear of the mainshaft, at the 7080 oil baffle, there is a groove that might hold a snap ring. Is this the problem?
juergen | -- 08-18-2019 @ 11:29 AM |
In taking apart some early trans, I have found two oil slingers to tighten up the main shaft.
40 Coupe | -- 08-19-2019 @ 4:36 AM |
There is no snap ring on the main shaft by the 7080 it is possible the 7080 was loose and wore into the shaft. are you checking fore/aft with the rear bearing retainer 5099 & 7085 in place? is the front retainer 7050 also in place? Have you checked the thickness of all the snap ring to make sure they are of proper thickness ( 0.075") some snap rings are too thin. After you bolt on the U-joint the 7080 should be tight on the shaft This message was edited by 40 Coupe on 8-19-19 @ 4:39 AM
nubes@bestweb.net | -- 08-19-2019 @ 6:38 AM |
Thanks for your response! Did not realize that the u joint had to be attached to the trans to take up the play. Thank you again.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13148 |
