48Tudor | -- 10-13-2009 @ 8:30 AM |
Greetings! We are working on a '47 probably built in the 2nd or 3rd month of production ( 275,000th out of 658,000). Car has lever shocks on the front and tube shocks on the rear and they appear to be factory stock. Anybody have any idea if this configuration was built during the '47 changeover? Thanks chr chr
wmsteed | -- 10-13-2009 @ 9:04 AM |
I believe that most of the '47 and later Fords had tube shocks on the rear. Bill 36 5 win cpe
supereal | -- 10-14-2009 @ 9:45 AM |
The the rear shock mounts fasten to the crossmember with clamps, they were added on. It would be unusual to find levers on the front, and tubes on the back, but with the '46-'47 models, anything is possible. Buy the Club's '41 to '48 book. It has lots of valuable info on your car, including several pages regarding shock absorbers.
48Tudor | -- 10-14-2009 @ 7:26 PM |
We sort have concluded that the rears may have been added later as the lower mount (arm off the backing plate) is not forged so it does not quite look like the arm pictured in the chassis parts book. Top mount bolts to the frame with U bolts. We have the 41-48 book but it was not really helpful in determining if the setup was original or added at a later date. Chart in appendix gives changeover dates for trim, etc but nothing for chassis changes. I'll try to get a photo of the lower arm and post for comment. Thanks ! chr
supereal | -- 10-15-2009 @ 10:26 AM |
In the haste to get cars to the dealers who were clamoring to satisfy the pent up demand for new cars after WWII, Ford used leftover '42 parts, and any others they could locate at that assembly plant. Due to price controls, the '46 cars were delayed until the middle of that year, and the '48 production was halted late that year to makeway for production of the '49s. That window of only about a couple of years meant many "running" changes, many of which were poorly documented, or not at all. That makes determining what is a "correct" configuration" often a guessing game. I have a '47 built late that year, and it is different from my '46 in a number of ways.
wmsteed | -- 10-15-2009 @ 12:41 PM |
When I converted my '36 Ford over to a '47-48 Columbia in lieu of the original '36 Columbia, the differential I used had the cast shock mounts attached to the backing plates. The shocks were attached to the cross member via U bolts. Many years later I found a '47-48 Ford that had the more correct mounting studs for the cross member. I guess that one could assume that the U bolt mount is a correct item for early '47 Fords.. Bill 36 5 win delx cpe
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=131 |
