36fordcvsedan | -- 06-26-2019 @ 10:56 AM |
Was someone making new top hinges for the trunk. All the reproductions are the shorter 2 hole version and I need the longer 3 hole . Similar to the 37 but without the ribs. Thanks.
37RAGTOPMAN | -- 07-01-2019 @ 10:46 AM |
HI you can try AL CASTEEN in VA AL@36FORDS.COM he is in the V8 MEMBERSHIP roster he is the expert on 36 CONVERTIBLE SEDANS, hope this helps 37Ragtopman
supereal | -- 07-02-2019 @ 11:09 AM |
C&G shows four types of hinges for your '36. Roadster, cabriolet, humpback 4 door, and coupe. Call them at 800/266-0470 and describe your car. Trunk hinges tend to be different enough between models of the same make that it takes an expert to know the difference. I ordered a set of hinges for my '47 convertible from Drake, and what they sent didn't come close. When I called them, they said "you must have an odd car because no one else has complained." When I called C&G, they said there are three types for the 41-48 convertible. I described mine, and received the ones that fit!
trjford8 | -- 07-02-2019 @ 5:06 PM |
Check with Wescott's Auto Restyling in Boring , Oregon. Karl is making a lot of different brass castings and he may have what you need.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13011 |
