SUPERTOOL | -- 06-24-2019 @ 10:16 AM |
Is there a way to tell if my pinion shaft is 6 spline or 10 spline without taking it all apart?
37RAGTOPMAN | -- 06-24-2019 @ 11:08 AM |
HI I think,,,,, if it has a grease fitting in the middle of the driveshaft it most likely has 6 splines, this is the solid drive shaft with a center bearing, no grease fitting it has the hollow drive shaft with 10 splines, I did this to my 37 about 7 years ago, installing a 354 gear ratio was not a fan of welding the 10 spline to 6 spline adapter to the hollow drive shaft. hope this helps 37Ragtopman the V8 SHOP has the high speed ring and pinons , they advertise in the V8 TIMES,
SUPERTOOL | -- 06-25-2019 @ 8:43 AM |
Thanks. I will take a look.
SUPERTOOL | -- 07-01-2019 @ 4:14 PM |
You were right, I took it down and it has a zerk and six splines.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13004 |
