jayd | -- 05-25-2010 @ 9:45 PM |
Anyone who's won a Dearborn with a 1950 Ford -the part's book calls for a lot of washers on bolts to be "S2" or raven finish. Is that correct?
Kens 36 | -- 05-26-2010 @ 7:21 AM |
Which parts book is specifying the S2 finish? Most washers on a '50 are S7 (cad) or S8 (zinc). Ken
jayd | -- 05-26-2010 @ 6:16 PM |
In the 1949-1950-1951-1952 Passenger car Chassis Parts asnd Accessories Catalog. Such things as horn brackets, engine thermostat housing bolts, coil bracket bolts, engine draft tube clamp bolts, etc. Thanks.
Kens 36 | -- 05-27-2010 @ 11:50 AM |
You are correct - the washers for the items you mentioned should be raven finish. Ken
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1299 |
