grilledstripedbass | -- 04-21-2019 @ 9:21 AM |
Have a 1934 Ford two door deluxe sedan Vineyard Green (original car ) looking to get this engine rebuild would like to find somebody in my general area of Rhode Island. Engine runs fine but it smokes when you give it any gas. Looking for a stock rebuild. thanks raymond_cabral@cox.net
MG | -- 04-21-2019 @ 10:35 AM |
Do you know if your engine has Babbitt main bearings? It's pretty hard to find a machine shop that can pour Babbitt these days. Maybe just a ring and valve job will do for you....
grilledstripedbass | -- 04-21-2019 @ 4:19 PM |
Not sure if they are Babbitt main bearings in my motor, did speak with a gentleman from New York that would make the needed Babbitt bearings we had a great conversation. Not that I don't want him to rebuild my 34's engine just looking for somebody closer to home. Now from what your saying there is more to rebuilding this engine the correct way than I thought. thanks grilledstripedbass
doghair3 | -- 04-22-2019 @ 5:56 AM |
Have you looked into Eastwoods Machine shop http://www.eastwoodsautomachine.com/
TomO | -- 04-22-2019 @ 6:09 AM |
grilledstripedbass , what color smoke are you seeing, black, blue or white? Black indicates excess fuel, white indicates a coolant leak and blue indicates oil usage. You should also have a dry and wet compression tests made on the engine to determine if the engine needs a rebuild. Tom
grilledstripedbass | -- 04-22-2019 @ 9:19 AM |
It’s a blue smoke I should’ve stated that earlier sorry .
grilledstripedbass | -- 04-22-2019 @ 9:35 AM |
Thank you for the Eastwood tip I did call Mark Eastwood and we did chat . Come to find out his shop is located right near my mother-in-law Thanks again!
len47merc | -- 04-22-2019 @ 11:00 AM |
Well grilledstripedbass, sometimes you have to take the bad with the good... Steve
Model B | -- 04-22-2019 @ 4:09 PM |
"Well grilledstripedbass, sometimes you have to take the bad with the good..." Now THAT'S funny! Pat
RIrover | -- 04-22-2019 @ 6:40 PM |
J m machine shop. In Massachusetts. Southborough. Excellent craftsman. Did my 40 flathead stock regards, David B Campbell
GK1918 | -- 04-23-2019 @ 5:32 AM |
Where about in RI, we are only about 20 minutes from E Prov. There is a good chance its not a Babbitt job and may have a later rebuilt. Other than that, we can rebore fit new pistons, all valves BUT if Babbitt we have to send it out. Blue smoke says top end, however if the top end is up to spec. then that will effect the bottom end, so that has to be checked out. Quick example thermo clean block magnaflux, clean bores next size 8 pistons & rings polish crankshaft check cam check oil pump check clearance rods mains full gasket set. Around 950 to $1100 and that was for a 59AB we did Dec. 30, 2018. As of now as I type this engine is as quiet as a cat on attack mode, gas mileage is unreal, power unreal perfect and this is my every day set of wheels.. I suggest; what I did was to install a fresh late engine so you have wheels while the original was rebuilt. Bottom line is many early V8s got 41 & up dealer factory rebuilts cause of no new cars during the war. I'm just ah saying. sam
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12841 |
