239al | -- 05-22-2010 @ 8:01 PM |
What kind of screws are used to fasten the dash to the cowl on a 1947 Ford? This car uses the same long screws to attach the dash to the cowl and to attach the window frames to the dash - doesn't seem right. Thanks.
supereal | -- 05-23-2010 @ 10:44 AM |
More often than not, the wrong screws have been used during the life of the car. My '47 had both straight and Phillips head screws. Bob Drake sells a complete kit of screws for your car. 800/266-0470. Depending on the model of your car, these kits are under $20.
42wagon | -- 05-23-2010 @ 12:29 PM |
Al You are in luck. Yesterday I put the dash back in my 42. This one had never been taken out before so I'm pretty sure I have the right fasteners. Along the top are 8 pan head sheet metal screws. In the bottom corners are 1/4" bolts and nuts. Didn't measure them but the pan head screws are probably 1/2" long. Ted
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1283 |
