dladrigan | -- 02-23-2019 @ 11:20 AM |
Need help. Anybody got info. on changing 39' Ford pickup rear torque tube drive to 42' Ford pickup open drive? Thanks, American Iron
40cpe | -- 02-23-2019 @ 2:42 PM |
The torque tube on the '39 keeps the rear end from rotating under acceleration/deceleration. The parallel rear springs do that on an open drive '42 truck. If you don't change to parallel rear springs, you will need to install a "backbone" to stabilize the rear. You will also have to convert your transmission to open drive if you continue to use it.
dladrigan | -- 02-24-2019 @ 6:45 AM |
Thanks for the info. Dan Flatties Forever
FAR32 | -- 03-01-2019 @ 8:24 PM |
Most of the truck open rear ends were very low geared. The tallest I have seen was a 4:11. You can't use passenger car gears in them because of the changes to accomidate the open drive. You would be better off using a 35-6 rear with the strong radius rods and use a conversion kit to get the open drive.
dladrigan | -- 03-23-2019 @ 11:14 AM |
I have a 42' banjo 3:78 I want to put the bells and axles from my 39' pickup on the 42' center section so I can keep my wide 5 lug pattern. The 42' has an open drive so I will have to add a backbone to prevent twist. Any plans out there for that anti twist fix? Thanks, Dan Flatties Forever
ford38v8 | -- 03-23-2019 @ 11:41 AM |
You're better off obtaining a 3.78 center section than to convert the whole system to utilize the open drive banjo you have obtained. Just a whole can of worms and expense you can avoid. Alan
dladrigan | -- 03-23-2019 @ 12:20 PM |
Thanks. Flatties Forever
dladrigan | -- 03-23-2019 @ 12:47 PM |
Can I take the ring and pinion out of the 42' center section and put it in the 39' center section? Thanks, Dan Flatties Forever
dladrigan | -- 03-23-2019 @ 12:49 PM |
dladrigan | -- 03-23-2019 @ 12:50 PM |
42merc | -- 03-24-2019 @ 5:32 AM |
No. The open drive R&P will fit the early housing, but - the truck pinion has a taper for the U- joint flange. The closed drive pinion has a spline to connect the drive shaft.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12701 |
