spongj3m3 | -- 01-03-2019 @ 12:16 PM |
Hello all, I am intending to swap my current 4.11 ratio ring gear and pinion out for a 3.54 ratio. I found a ring gear and pinion on Early Ford V8 Sales https://www.parts123.com/parts123/dyndetail.pta?acclink=0000019a04363 and was wondering whether anyone has had any experience with either this product or company. Would any cutting/grinding or modifications be needed for this or is it an easy replacement? Thanks in advance Joshua
CharlieStephens | -- 01-03-2019 @ 1:00 PM |
You should add your general location to your profile. Maybe you are close to some that knows how to set up these rear ends. Charlie Stephens
alanwoodieman | -- 01-04-2019 @ 10:21 AM |
I buy a lot of parts from these guys, always easy to do business with, stand behind their products and have good service if there is some sort of issue.
alanwoodieman | -- 01-04-2019 @ 10:22 AM |
TomO | -- 01-05-2019 @ 8:53 AM |
There should be no cutting or grinding, but you will need to set the gear mesh and preload. The instructions are in the Service Notes. I am not familiar with the 34, but it may have a different spline than the one adverised. Tom
LD PARKER | -- 01-09-2019 @ 4:20 AM |
I have bought lots of parts from the folks at Early Ford V8 Sales. They are very professional and stand behind their products. Great parts supplier!
LD PARKER | -- 01-09-2019 @ 4:22 AM |
LD PARKER | -- 01-09-2019 @ 4:23 AM |
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12590 |
