knuckle44 | -- 12-25-2018 @ 7:50 AM |
Apparently by worm gears are out of synch. I can turn one direction tighter than the other. I assume I will have to remove the housing end plate to get enough free play to make an adjustment in the gear alignment. Are there any markings in the gears that need to be aligned? That is, how do I know when I have it set up correctly. FYI: I probably scr*w*d things up when I had this box apart and the gears did look to be in good condition. Thanks and Merry Christmas to all!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12563 |
