Bob56 | -- 12-08-2018 @ 3:29 AM |
How tight do you make the spring bolt on 1936? What gauge safety wire do I use for the bolts?
nelsb01 | -- 12-08-2018 @ 4:36 AM |
I just did mine on my 1936 pickup. I snugged down the bolts, till i could see that they were completely through the cage nuts. I used wire that is available at a local hardware store. The two bolts on one side are wired to each other. The side with the spring is wired through the frame -- look for a slight bend in the frame and that is where the wire goes around and then back through the bolt head. (thanks Don Rogers) Hope this helps.
Bob56 | -- 12-08-2018 @ 7:27 AM |
Thank you. that's what I needed
kubes40 | -- 12-08-2018 @ 12:47 PM |
Bob56, Be sure you allow the spring some "room" for it to do its job. In other words, do not bind the coils. Both sides of the frame have a "bump out" and as such, both sides should be wired through them. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12523 |
