mfirth | -- 11-26-2018 @ 9:30 AM |
O k, this is peat & repeat, but, what is the correct 6 volt light bulb for 1952 Ford car tail/stop & park/turn lights. Different vendors say different things. THANKS Folks. mike
TomO | -- 11-26-2018 @ 3:06 PM |
The correct bulb is probably the 1154 bulb and can probably be bought at Autozone or other local parts suppliers. The 1154 bulb has offset prongs, if your bulb has prongs that are aligned, the bulb is 1158. I said probably because most post WWII cars used that 1154 bulb, pre WWII cars predominately used the 1158. Tom This message was edited by TomO on 11-26-18 @ 3:13 PM
mfirth | -- 11-27-2018 @ 3:44 AM |
Thanks Tom O ! My bulbs i d numbers are worn & hard to read.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12505 |
