fatso2114 | -- 11-23-2018 @ 2:01 PM |
Hello,going to rebuild my steering box on my 50 ford 2 door was wondering how the worm gear is attached to the steering shaft ,is it pressed or keyed or what and how much play should I have ,lash between the sector and the worm gears thanks John
TomO | -- 11-24-2018 @ 8:10 AM |
John, the gear is pressed on and you should follow the procedures in the 1949-1951 Shop Manual to set the clearance. It is available from most vendors as a reprint and on a CD. https://www.macsautoparts.com/ford_mercury_late/ford-shop-manual.html https://www.themotorbookstore.com/1949-1951-ford-factory-shop-manuals-cd.html?cmp=googleproducts&kw=1949-1951-ford-factory-shop-manuals-cd&gclid=CjwKCAiAiuTfBRAaEiwA4itUqKbXBl7KECQlt5gVFpB5c4PJWuaXZcbfLQ5xzs1IsuCjfi0c3wEg_RoCjQQQAvD_BwE I prefer the CD version because I can printout the information, take it to the car with me and not worry about getting grease on it or ruining the binding on the manual. Tom
fatso2114 | -- 11-24-2018 @ 8:14 AM |
Thanks Tom, you guys are a great help,John
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12499 |
