maxjay0527 | -- 11-10-2018 @ 7:12 AM |
Does the rear window need to be removed to replace the headliner??
cliftford | -- 11-11-2018 @ 5:19 AM |
No, See a post on this subject under 1940 f0rds.
kubes40 | -- 11-11-2018 @ 6:47 AM |
Well, no it doesn't NEED to be. However, to do the job as it was originally done and to do it well, then yes, the rear window should be removed. Mike "Kube" Kubarth
trjford8 | -- 11-11-2018 @ 6:47 AM |
The '41 rear window gasket is the same as the 42-48 gasket. There's no garnish molding and the window needs to be out to do the headliner properly. The gasket holds the headliner tight to the rear of the car.
trjford8 | -- 11-11-2018 @ 6:48 AM |
maxjay0527 | -- 12-01-2018 @ 10:46 AM |
Thanks!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12473 |
