joesgarage149 | -- 10-18-2018 @ 2:50 PM |
I have a 48 ford sedan that I am installing a chassis engineering drop front axle kit on. I have to split the wishbone and was wondering if anyone had any information on the process and where to get a kit/parts for this. Any help is greatly appreciated..
CharlieStephens | -- 10-18-2018 @ 3:03 PM |
You would probably get better responses if you posted your question on HAMB: https://www.jalopyjournal.com/forum/forums/the-hokey-ass-message-board.5/ This site focuses on original or restored early Fords. Good Luck. Charlie Stephens
woodiewagon46 | -- 10-18-2018 @ 3:05 PM |
If you are using a Chassis Engineering Kit, instructions should be included. Don't forget, when you split the wishbones you will need to heat and bend the spring mount. If you can't locate the instruction sheet I can snail mail you a copy.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12416 |
