mfirth | -- 10-01-2018 @ 1:29 PM |
Fresh 8ba with 400 miles runing Valvoline racing 10w30.oil. One valve started ticking . Took it to the builder & he said he'd go thru it & readjust later in the month. Took a ride 2day & no ticking.????.......any ideas appreciated. THANKS fella's ! mike
GK1918 | -- 10-02-2018 @ 3:51 AM |
Sometimes engines need a few heat & cold cycles. Parts have to get use to each other. Don't baby it , it needs a load, like the old school found in any book- give it the boot let of the gas that sucks oil up in cylinders and do it again. I think its too early 400 mi to worry about adjusting valves.
cliftford | -- 10-02-2018 @ 4:47 AM |
If it is a sticky valve, I doubt that readjustment will make any difference.
flathead4rd | -- 10-02-2018 @ 5:25 AM |
A little more information needed. Does it have adjustable lifters? If not just drive it some more and see if it goes away.
mfirth | -- 10-02-2018 @ 6:24 AM |
Thanks everyone. It has adj. lifters, and as i said it just quieted up . That's why i wonder if new valves and guides would stick when i'm using high quality oil. Time for M M O i guess. m
TomO | -- 10-02-2018 @ 6:57 AM |
I would try Mobil 1 synthetic oil first. It will lubricate better than the Racing oil. The synthetic oil gets into places that the dinosaur oil doesn't. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12377 |
