MICHV8 | -- 09-25-2018 @ 2:56 PM |
Anybody know why the 40-48 dash light dimmer switch won't work on a 39?
TomO | -- 09-26-2018 @ 6:54 AM |
The dash light dimmer switch is just a wire wound variable resister that drops the voltage to the lights. Any dimmer switch that will fit the dash will work. Tom
MICHV8 | -- 09-28-2018 @ 4:40 AM |
right...so the mounting dimensions must be different...anybody know?
supereal | -- 10-14-2018 @ 1:32 PM |
The dimmers for 40-47 are available from C&G(800/266-0470). Be aware that they are somewhat pricey at about $25. They tend to be troublesome, at best, and given limited use, most imply bypass the dimmer by connecting the wire together, and leaving the unit in place for appearance.
MICHV8 | -- 10-14-2018 @ 5:58 PM |
thanks, Bud
MollD1974 | -- 10-15-2018 @ 8:15 AM |
So, supereal, does bypassing the dimmer mean the unit no longer is dimmable?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12364 |
