36fordor | -- 05-12-2010 @ 9:01 AM |
(1) How are the 36 Ford parking lights turned on? Where's the switch? (2) Can you confirm how the headlight brights are turned on brights? First position left dim & 2nd position left brights? (3) Instrument lights should turn on by pulling left knob out on dash? Thanks.
40 Coupe | -- 05-12-2010 @ 1:12 PM |
for 36 push the dash light switch in to light the dash and out to turn them off.rotate the outter ring of the horn rod CW turns on parking lights, if rotated CCW to the first position is high and second detent CCW is low
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1235 |
