ken ct. | -- 09-11-2018 @ 4:20 AM |
On a 36 the back side with the black bakelite cover with the 2 screws and 2 stud connections. Will anything pop out if I remove said cover,like springs small parts never to be found again,simple question ??? ken ct (IGNITION SWITCH)
kubes40 | -- 09-11-2018 @ 5:00 AM |
Ken, there is a small contact brush in there that even if dropped will be easy to locate. that's it ![]() Mike "Kube" Kubarth
ken ct. | -- 09-11-2018 @ 6:22 AM |
Thanks ,I have a new contact piece to put in soooo !! ken ct. Hoping that's my problem,otherwise I have new cond. and resister unit I will put in there. This message was edited by ken ct. on 9-11-18 @ 6:25 AM
JM | -- 09-11-2018 @ 8:58 AM |
Ken, you might want to carefully clean up the inner side of the bakilght backing with a very fine sandpaper on a flat surface. This will clean the stationary contacts to make good contact with the pivoting cantact arm you are replacing. John
ken ct. | -- 09-11-2018 @ 10:44 AM |
Will do John. thanks ken ct.
MG | -- 09-11-2018 @ 10:59 AM |
"otherwise I have new cond. and resister unit I will put in there." Ken, splain to me about this "cond. and resister" thing you are thinking of doing.... https://www.ebay.com/itm/Ford-1932-37-ignition-switch-terminal-plate-body-column-drop-flathead-key/261900928193?epid=2275576945&hash=item3cfa8304c1:g:pIQAAOSwBLlVYnxl:sc:USPSFirstClass!95125!US!-1&vxp=mtr https://www.ebay.com/itm/NOS-1932-37-Ford-ignition-switch-brush-contact-B-3709-column-drop-terminal/263593653319?epid=1753246369&hash=item3d5f67f447:g:yy4AAOSwGeRayXny:sc:USPSFirstClass!95125!US!-1&vxp=mtr This message was edited by MG on 9-11-18 @ 11:40 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12332 |
