rebrown | -- 09-02-2018 @ 2:12 PM |
I have found multiple posts on what grease to use in the steering box but no mention of the quantity needed to refill one. I am going to work on mine and drain it when I replace the end plate gasket. I would like to order JD CHG or Penrite but I need to know how much. This message was edited by rebrown on 9-2-18 @ 2:15 PM
ken ct. | -- 09-02-2018 @ 3:18 PM |
You would be lucky if it took 1/2 to a pint of whatever you put in it. Fill to the plug and that's it. ken ct.
rebrown | -- 09-02-2018 @ 4:10 PM |
Thanks.. not much at all. Will corn head grease pour or do you need to squeeze it in?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12300 |
