parrish | -- 05-11-2010 @ 8:09 AM |
The car is early 36 so it has the standard steering wheel, not the banjo...will a 39 banjo work? I noticed the 36 wheel does not promote a puller type removal approach. Is there a trick? Thanks!
tudorbilll | -- 05-11-2010 @ 10:05 AM |
The wheel has to be lifted from the bottom.there is a speceil tool made for this job . you will have to use the horn button that comes whith the wheel.they are diff Diamitors.Bill
35Phaeton | -- 05-13-2010 @ 9:36 AM |
I too need to remove the steering wheel on my 35 Ford at some point and have woundered the same thing.....check out the attached link to an article I found a while back. Jim http://www.vanpeltsales.com/FH_web/1939ford-project-restoration-8.htm
parrish | -- 05-15-2010 @ 7:47 PM |
that's great! thanks for the link...
parrish | -- 05-16-2010 @ 8:27 AM |
thanks to Bill too!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1228 |
