Johns46coupe | -- 05-10-2010 @ 1:43 PM |
Hello. My 46 Ford's temp gauge pegs over to max after the car runs only a short time, about 15 minutes of light driving. Using a mechanical thermometer, the max coolant temp is 165 degrees idling after one of these jaunts. I suspect a bad sender but don't know how to tell which one. Is there a way? The right sender is grounded well and measures 14 ohms to ground when engine is warm, infinity when hot. On the left side, both long and short tabs measure infinity to ground warm. All measurements are with wires disconnected. At the same time as all this, my gas gauge quit working but don't know if that's related. The car has a 6V alternator. Just prior to this, I had the radiator boiled out and pressure tested (He doesn't do flow tests but said all is well). I also had the carb rebuilt, I rebuilt the distributor (set it by measuring), installed new Drake waterpumps, new 180 degree thermostats, new hoses. The heater valve is open and I have a 4 pound radiator cap on. Belts are tight and there are no coolant leaks or overflows. The car runs strong, lots of power, no smoke or steam. I have not attempted to adjust the vacuum brake yet. Any ideas what's going on? Thanks for reading this long missive!
G Tosel | -- 05-10-2010 @ 2:12 PM |
According to the 1941- 1948 Complete Service Bulletins No.10883 March 18, 1948 the temperature dash gauge is in the hot position when the ignition is off. When the ignition is on, the gauge will move toward the cold position before going to the measured temperature. Is that your set-up? In addition the right unit is grounded in the cold condition. If you can get a copy of the Service Bulletins it will answer your questions to diagnose the problem.
Stroker | -- 05-10-2010 @ 2:15 PM |
Somewhere in my ageing memory, I recall that Ford used a overheat ignition cut-off on one cylinder head. This was a tar-filled sensor that was not intended to be a heat gage sender, but rather an ignition cut-off. Is it possible that you have your temp gage connected to one of these? The idea was: when the engine became really hot, the tar would melt and interrupt a set of contacts which were connected in-line with the coil primary, and essentially shut the engine off. Ford of course would imply that you then needed to correct the problem, and install a new cut-off. Economically challenged dirt farmers would simply take the unit into the kitchen and cook it upside down in a double boiler until it re-set. I have no idea if this is related to your problem, but I have not seen "temp sending units" used on both heads except for after-market applications. What say the Experts?
Johns46coupe | -- 05-10-2010 @ 2:23 PM |
When turned off, the gauge is max to the right as you note. When I turn it on, the needle moves slowly left to the measured temp. I'll look for the service bulletin. Thanks
Johns46coupe | -- 05-10-2010 @ 2:27 PM |
Stroker, As I understand it, both are sensors on my car. On the left side, there are two tabs, the short one is for the wire to the gauge, the long one for the wire to the other sensor on the right. In any case, the ignition seems fine and it starts easily. Other thoughts?
G Tosel | -- 05-10-2010 @ 2:49 PM |
You are correct both are sensors and they are wired in series. Alternate heat created from ignition current on gauge and water heat from sensors causes these sensors to make and break contacts to match water temperature. Service Bulletin Subject 14999-Z shows procedures to troubleshoot sensors and gauge. Thanks
Johns46coupe | -- 05-10-2010 @ 2:54 PM |
G Tosel. Thanks again. Any idea if service bulletins are available online?
51f1 | -- 05-10-2010 @ 5:41 PM |
I wrote instructions for checking the temperature gauge and sending units some time ago. I'll add it below. You can probably skip some of the gauge testing and go straight to the sending units. The sending units and the thermal switch in the block are connected in series so that either switch will cause the gauge to read hot, but only the sender with one terminal actually reads the temperature (in the right cylinder bank only). The thermal switch with two terminals is only an on-off switch. It turns off when the cylinder bank overheats at about 212 degrees F. Probably either the sending unit or the thermal switch is opening (turning off) below 212 degrees which gives you a "HOT" indication on the gauge. You have two units because the two cylinder banks, unlike modern v-engines, are not internally connected. Instructions For Testing V-8 Temperature Gauges: With the ignition switch on and the engine cold, if the gauge is reading "cold," it is working, and you can skip this step. If not, with a voltmeter, check the voltage at the gauge with the ignition switch on. Touch the terminal on the gauge that is connected to the power supply with the negative volt meter lead and connect the other lead to a good ground. If you don't get six volts you need to determine why. If you have six volts to the gauge, proceed. With the ignition switch on, ground the terminal on the gauge that is connected to the sending unit and the thermal switch. The gauge should read "cold." If it doesn't it's bad. There is a temperature sending unit (one terminal) in the engine block on the right-hand cylinder head looking from the driver's seat. The other unit is a thermal switch (two terminals) located in the left-hand head. These are connected in series. If either of these switches is stuck "open," it will cause the gauge to read "hot." With the ignition switch on, disconnect the wire on the thermal switch (left head) that goes to the gauge and ground it. (You can ground it by touching it to the body of the thermal switch.) The gauge should read "cold." If it doesn't, and you have determined that the gauge is working, there could be an open circuit (broken or disconnected wire from the sending unit to the gauge or even a bad engine ground). If the gauge is reading "cold," reconnect the wire. Disconnect the wire at the right hand unit that runs between the two units and connect it to a good ground (the body of the unit). If the gauge does not read "cold," the thermal switch (left head) is probably bad. Replace it. If it does read "cold," the sending unit (right head) is probably bad. Replace it. Richard
Johns46coupe | -- 05-10-2010 @ 6:47 PM |
Thanks for the procedure Richard. I'll jump on that as soon as it cools down. I bought the book of service bulletins this afternoon but this will get me going. I'll let you all know how it goes! Thanks all, John
TomO | -- 05-11-2010 @ 7:37 AM |
John, I would also look at the connections at the gauge. When there is no voltage supplied to the gauge, it will move toward the hot side. The gas gauge would move to the empty side if voltage were removed. You can bypass the sender with the 2 terminals by connecting both wires on one terminal. Drive the car and if the indicator does not go to hot, it is the sender with the 2 terminals that is failing. If it does go to hot, it is the sender with 1 terminal failing. I would not try to diagnose the problem with a voltmeter or an ohmmeter, because the conditions change as the engine heats up. The one terminal sender consists of a coil wrapped around a bi-metal strip with contacts at the end. When the contacts close, current flows in the circuit heating the bi-metal strip in the sending unit and in the gauge, causing the gauge needle to move. As the engine heats up, the contacts are further apart and less current flows in the circuit. The ohmmeter would read an open circuit on the single terminal sender, when the engine is warm, because the contacts are open. Tom This message was edited by TomO on 5-11-10 @ 8:58 AM
supereal | -- 05-11-2010 @ 8:22 AM |
The sensor with the single terminal has an internal heating coil to properly set (bias) the unit. The points in the sensor actually vibrate as they open and close, and the rate is in proportion to the surrounding (ambient) heat. If the coil in the sensor is broken, or otherwise failing, it is likely the gauge reading will behave as you describe. Lack of proper grounding of the body of the sensor will also interfere with the operation. The two terminal sensor is just a thermostatic switch that opens when at or near the boiling point of the coolant. To eliminate it as a cause, simply short the two terminals together. If the problem goes away, that sensor is bad. The only cure for a defective single terminal sensor is replacement. Repro sensors are of suspect quality if not NOS.
Johns46coupe | -- 05-11-2010 @ 10:26 AM |
Thanks for all the help Richard, Tom and Super. Here is where I'm at. When the engine is cold, the gauge reads cold, OK so far. Also, when cold I can read the voltage on the right hand sensor and see the "vibration" Super mentioned. Seemed to be about two pulses per second or so. Went for a drive and the gauge started going up slowly, as normal, held steady around the TE area for a bit, then slowly went to full hot. I put a jumper across the two terminals on the left sensor and the gauge did not change.. Stopped the engine and while still hot, grounded the right sensor wire with the ignition turned on. Gauge immediately went cold. As the car cools off and I monitor the gauge, it slowly moves to cool as you would expect it to. At this point, I suspect the right sensor is not totally failing but is sending incorrect info because the gauge moves gradually and because grounding the right sensor causes an immediate cold reading on the gauge. Am I reading all the smoke signals correctly?? Thanks, John
supereal | -- 05-11-2010 @ 11:44 AM |
That says that the gauge and the associated wiring is OK. I assume that you have put a reliable thermometer in the radiator neck to check the actual temperature and confirm that the coolant is not rising to near or past the boiling point. At a temperature in the 180-190 range, the gauge usually reads at, or just above the center of the dial. Check the actual temp of the coolant when the gauge reaches that point, and again when the needle goes over toward the H peg. If the coolant temp is still below the 180-190 region, the sensor is bad. If the coolant is hotter, in the 200-210 range, you have a cooling system problem, which can range from a partially clogged radiator to a slipping water pump belt, to a leaking head gasket. I've even seen dragging brakes cause overheating.
Johns46coupe | -- 05-11-2010 @ 1:07 PM |
Thanks Super. I have checked the coolant temp with a mechanical thermometer with the car idling and saw a temp of 165 degrees although the gauge was at max at the time. Also, when turned off, the fins at the top of the radiator were hot and were noticeably cooler at the bottom, as you would expect. I don't think the belts are slipping although the pumps are new Drakes so are a little stiffer than the old ones. Thanks, John Thanks, John
51f1 | -- 05-11-2010 @ 3:55 PM |
Sounds like it's the temperature sending unit (one wire) on the right head. The way you describe the symptoms, that makes sense. Richard
TomO | -- 05-12-2010 @ 8:01 AM |
The right sensor is the one causing the problem. Try removing the sensor, cleaning the threads on the sensor and the block, then re-installing the sensor with a small amount of pipe dope on the first couple of threads. Teflon tape and other sealing compounds may compromise the ground circuit. Tom
Johns46coupe | -- 05-12-2010 @ 2:49 PM |
Many thanks you guys. I have a right sensor on order that should be here Fri or Sat. I'll update this discussion with the results. I sure learned a lot from everyone about cooling systems and senders. Thanks, John
Johns46coupe | -- 05-16-2010 @ 12:13 PM |
Well, assuming my right sensor was bad and the new one not having arrived yet, I was driving around ignoring the temp gauge when the car started running rough. I pulled over and the coolant was overflowing and the engine really was overheating. When I got it home I was prepared for the worst. I checked compression and it varied from 105 to 120 pounds. Great. I re-read the posts and Super had said use a "reliable" thermometer to check coolant temp which had been 165 deg. I had borrowed it so I compared it with a meat thermometer and found it had been reading 25 to 30 deg low. I then removed the two new thermostats and boiled them along with my old stats. One of the new stats opened but not much and the other one not at all. The old ones opened wide. I've decided to run with no stats and the temp gauge only goes up about a quarter of the way. The moral of the story is be skeptical concerning new parts and use reliable (thanks Super) test equipment. Many, many thanks to everyone who responded with ideas and suggestions. You certainly taught me a lot. Thanks again. John
TomO | -- 05-16-2010 @ 5:20 PM |
John, we have all been led down the primrose path by faulty test equipment. Go to your local hardware store and buy a candy thermometer. They come with a hand clip that allows you to clip it to a pan. You can test it by clipping it to a pan of water and bringing the water to a boil. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1224 |
