gfstew | -- 08-10-2018 @ 2:58 PM |
I took the Generator off to have it checked because I had a bad cell go out on the battery. so I installed the Generator back on and installed the new battery I have the correct termnial to the posative ground the car starts up OK but now I have no headlights or park light nothing?? it has the orginal steering wheels on the car and the lights worked before the I replaec the battery. and I fuse looks OK What happened ??
MG | -- 08-10-2018 @ 3:07 PM |
What year car do you have? Sounds like you blew the fuse usually found under the dash....
gfstew | -- 08-10-2018 @ 5:38 PM |
1936 Ford 2 door sedan I only found 1 fuse yes under the dash
MG | -- 08-10-2018 @ 6:09 PM |
Yes, there is only that one fuse for the lights. Did you remove and test it? Is it open? Do you have a replacement fuse?....
cliftford | -- 08-10-2018 @ 8:53 PM |
I have found fuses that "look okay" and are actually bad.
cliftford | -- 08-10-2018 @ 8:54 PM |
JM | -- 08-14-2018 @ 10:49 AM |
You can say that again ![]() ![]() Did you find a good fuse to install, and did the lights work again? Just wondering. John This message was edited by JM on 8-14-18 @ 10:53 AM
gfstew | -- 08-14-2018 @ 3:45 PM |
Yep I put a 25 amp fuse in it and now I have lights
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12227 |
