jakes | -- 08-06-2018 @ 8:01 AM |
Working on a 1937 cub cabriolet. Having a recurring no spark issue. Replaced the coil, plug wires, plugs, points, distributor caps, set to spec's. Engine started a ran fine. Regularly started engine until I had a chance to road test it. Went to start, no spark again. When researching this problem on the forum there was another question similar. I followed the instruction by checking the voltage at the coil wire (disconnected from the coil). From what I understood it should be 3.5 volts. Mine was less than 1/2 volt. The forum did not address what to do if the voltage was below 3.5 volts. Any suggestions on where I can go from this point? Thanks, Jakes
CharlieStephens | -- 08-06-2018 @ 8:45 AM |
Since the resister is what reduces the voltage I think I would start there (including the connections to it). Charlie Stephens
1937sedandelivery | -- 08-06-2018 @ 9:22 AM |
Hi Jake, You may already have this, but thought I would attach the wiring diagram to use as reference during this post/debug. I highlighted points A, B & C as measurements of interest. gregg
jakes | -- 08-06-2018 @ 12:56 PM |
Thanks Charlie, that was it. Finally something that doesn't cost an arm and leg to fix. Thanks again, Jakes!!
jakes | -- 08-06-2018 @ 12:58 PM |
Gregg, thanks for your input regarding my problem that turned out to be the resistor. Thanks, again Jakes.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12198 |
