dggohl | -- 08-06-2018 @ 6:58 AM |
I have a 52 Ford with a 53 Merc Flathead. I've installed a new Champion radiator. After driving to get the car good and hot but not overheated, gauge in normal zone, I leave it sit for a while, then its very hard to start. Could this be a points problem? To wore? Or since the Merc engine had the auto choke, could that be the problem? Suggestions?
TomO | -- 08-07-2018 @ 6:33 AM |
Do you have the Ford intake and carburetor or the Merc intake and carburetor? Have you checked your spark for a strong spark when idling? Have you checked the timing with the vacuum advance disconnected and the idle set to specified RPM? Does the starter turn over the engine at a normal rate? Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12196 |
