Zero | -- 07-22-2018 @ 10:13 AM |
on the body is a 1.5 in x 1.5 in 1/4 thick piece of rubber that the check arm goes thru. I'm having difficulty finding a vendor for that piece. Above and below the slot are holes where the piece may have been riveted to body. I checked with Steele, Carpenter, Drake, Mac and C&G and none carry that part. Any suggestions?
trjford8 | -- 07-23-2018 @ 1:55 PM |
That particular rubber item is not reproduced. You will have to invent something yourself to take it's place. It's basically in the door as an anti-rattle device for the door check arm/
Zero | -- 07-23-2018 @ 4:14 PM |
TRJ, Thanks for the info. I think I may have a solution. By cutting one of the round bumper stops in half and gluing it in place it may just solve my problem. Again, thanks for getting back to me. John
GK1918 | -- 07-24-2018 @ 2:13 AM |
I use shock absorber rubbers.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12148 |
