silverchief | -- 05-08-2010 @ 2:22 PM |
On any old car - what problems if any might be expected from using a 7 lb radiator cap, when the owner's manual calls for a cap with 17 lbs pressure. Thanks in advance.
ford38v8 | -- 05-08-2010 @ 4:43 PM |
Chief, none of our old Fords take a cap of more than 4 lbs, or the tanks may rupture. If your car manual specifies 17 lbs, you would likely lose a considerable amount of coolant with a weaker cap. Alan
supereal | -- 05-08-2010 @ 5:15 PM |
I've never seen an owner's manual for anything that called for a 17 pound radiator cap. Even 7 pounds is pushing it a bit. 4 pounds is usual. At 17 pounds, I would expect one or both radiator tanks to pop. While a pressure cap does raise the boiling point of the coolant, and can help contain overflow, it is no substitute for a system in good condition.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1213 |
