KAS1954 | -- 07-10-2018 @ 4:22 PM |
Afternoon gents I’m trying to remove the field coils on the generator housing, what would be the best tool to do so? Thanks -Keith
cliftford | -- 07-10-2018 @ 8:12 PM |
Try taking it to an auto electric shop that's been around for a while. They may have the special tools for this. Sometimes you can take a sharp chisel and turn the countersunk bolt by tapping the screw slot.
cliftford | -- 07-10-2018 @ 8:16 PM |
CharlieStephens | -- 07-10-2018 @ 10:46 PM |
How about a picture, is it a standard screw or a square countersunk? The last time I saw it done in a shop they used a V block to hold the generator on a drill press table. They put the tool into the chuck so they could hold it down firmly. I don't remember if the tool was a cut off screwdriver or a piece of square stock. I don't remember if the tool had a handle to turn or they just turned the tool with a wrench. Charlie Stephens. This message was edited by CharlieStephens on 7-10-18 @ 10:47 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12110 |
