Nangeo | -- 07-01-2018 @ 4:40 PM |
my 39 slips out of 2nd gear Any suggestions/ Thanks George V.
JM | -- 07-02-2018 @ 1:51 AM |
That's normally an indication of wear on internal surfaces of housing and/or gears, which may require rebuilding the transmission to correct the problem. John
FordFreak | -- 07-02-2018 @ 5:21 AM |
On my truck it was nothing more than a worn pin in the shifter , which was very loose horizontally . Does yours have excessive movement when you move it side to side ? If so , call Charlie Schwidler @ 716-440-8952 . He is a great guy & is very reasonable . - F F
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12082 |
