autoluke | -- 06-29-2018 @ 5:18 AM |
Rear bearing has been growling lately, and can be partially silenced with a few drops of oil. In order to have peace of mind I have decided to operate. Question: Is the bearing replacement a bench job, or should I take it to a professional ?
kubes40 | -- 06-29-2018 @ 6:07 AM |
If you have any mechanical skills whatsoever, you'll handle this task easily. Bearing is a very common one that can be purchased at any decent auto parts supplier. Mike "Kube" Kubarth
TomO | -- 06-30-2018 @ 8:52 AM |
Most of the 32-48 generators have a bushing for the rear bearing. Usually these are pressed in and then reamed for correct shaft size. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12072 |
