DC8tech | -- 06-05-2018 @ 6:13 AM |
Has anyone been successful with a voltage regulator or a volt dropping resistor? If so, what did you use and where to acquire the part? And are there issues with polarity, positive gnd vs negitive gnd?
TomO | -- 06-05-2018 @ 7:23 AM |
You need a voltage converter that can handle the current that the radio draws and has a regulated output. Tom
fenbach | -- 06-05-2018 @ 7:59 PM |
check out this discussion. just ignore the static. https://www.earlyfordv8.org/forum/viewmessages.cfm?forum=18&topic=11084
DC8tech | -- 06-06-2018 @ 3:09 PM |
Thx fenbach. i have found out that my 2MF radio is a 6 tube model that draws in 6 amp range. So the Power Converter Regulator on Amazon is good up to 10 A and has built in overload, over current and over voltage protection.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11975 |
