tgt4446 | -- 05-26-2018 @ 8:27 PM |
is there any special consideration to take when removing the tail light from the fender? This car has a heavy undercoating from years ago so the mounting bracket isn't clearly visible.
1934 Ford | -- 05-29-2018 @ 9:54 AM |
You have to get to the two mounting nuts on the underside of the fender. Happy scr*ping. There will also be a metal wire cover under there with another nut at on the fender to body mounting bolt. I wish I knew what dissolves undercoating. Anybody out there know? 1934 Ford's since 1972 This message was edited by 1934 Ford on 5-30-18 @ 5:23 PM
TomO | -- 05-30-2018 @ 7:06 AM |
Eastwood sells an undercoating removal product that works with lots of effort. A gasoline leak removed the undercoating on the gas tank of my Lincoln. The Eastwood product is safer to use. Tom
trjford8 | -- 05-31-2018 @ 6:55 AM |
Mineral spirits paint thinner may soften it for removal. It would be safer than using gasoline.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11958 |
