Joeellsasser | -- 05-26-2018 @ 8:12 AM |
The top of the head bolts are paint engine green. Is this correct or should they be black?
kubes40 | -- 05-26-2018 @ 9:13 AM |
The head studs were not painted at all. Plus, the heads were not painted. They (heads) were left in their natural state - aluminum. So - not sure what you have going on there...I'm guessing either a completely incorrect engine or at the very least incorrect heads. Mike "Kube" Kubarth This message was edited by kubes40 on 5-26-18 @ 10:54 AM
Joeellsasser | -- 05-26-2018 @ 9:29 AM |
Kube, were the head bolts black looking bolts like most of the other fasteners on the roadster?
ken ct. | -- 05-26-2018 @ 10:32 AM |
1934 to 1948 used studs and nuts NOT BOLTS which you keep referring to. ken ct.
kubes40 | -- 05-26-2018 @ 10:52 AM |
They (the studs) were left in their natural state so yes, a kind of flat / satin black. Cadmium plated nuts and flat washers completed this "unit"... Mike "Kube" Kubarth
3w2 | -- 05-26-2018 @ 1:11 PM |
Hmmm. My catalogues read S8 (zinc), not S7 (cadmium) for the nuts and S7 for the washers used with aluminum heads. That's through '34; maybe they switched to S7-finish nuts after that. I agree that the studs had a S2 finish (black oxide). No, I am not referring to the 1948 green book. This message was edited by 3w2 on 5-26-18 @ 1:13 PM
1934 Ford | -- 06-04-2018 @ 4:35 PM |
My nuts are not painted either (34 Fordor V8) 1934 Ford's since 1972
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11956 |
