dtlewis | -- 05-17-2018 @ 9:38 AM |
Is it a good idea to paint the external surface of a new master cylinder to prevent rust from forming? I thought a good grade of oil based black would be a good protectant. I realize this is not a factory original practice.
4dFordSC | -- 05-17-2018 @ 1:44 PM |
Any spilled brake fluid would likely deteriorate the paint. This message was edited by 4dFordSC on 5-18-18 @ 3:59 AM
shogun1940 | -- 05-24-2018 @ 5:58 PM |
I would prime it and paint it. Then just do not over fill
kubes40 | -- 05-24-2018 @ 7:40 PM |
I use Eastwood's "cast iron" paint. It allows for a protective finish and is a decent approximation of "fresh" cast iron. Mike "Kube" Kubarth
CharlieStephens | -- 05-24-2018 @ 10:25 PM |
I think the Model A guys use model airplane paint on their carbs. This is the paint that keeps the paint from dissolving when the fuel from the airplane engine gets on it. You might check that out. Charlie Stephens This message was edited by CharlieStephens on 5-25-18 @ 5:23 PM
trjford8 | -- 05-28-2018 @ 11:07 AM |
I've used the clear POR-15 over the natural cast iron finish on my master cylinders. Seems to hold up good.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11934 |
