bgalla | -- 05-04-2010 @ 5:54 PM |
Did cast iron heads have a washer under the head nut?
ford38v8 | -- 05-04-2010 @ 10:13 PM |
No, only aluminum heads had washers to prevent galling. Alan
37RAGTOPMAN | -- 05-05-2010 @ 4:50 PM |
the original type nuts had a round surface on the bottom of them,kinda hard to explain here, these was for the cast iron heads,and sorted acted like a washer,if you need nuts buy from ROY N to get the CORRECT ONES, hope this helps, KEEP ON TRUCKIN''' 37RAGTOPMAN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1192 |
