JohnA | -- 05-02-2018 @ 5:47 PM |
If I thought I had a sticky valve on my 239,how should I deal with it.
fla48 | -- 05-02-2018 @ 7:21 PM |
Have you tried Marvel Mystery oil?
flathead4rd | -- 05-03-2018 @ 6:35 AM |
Put a vacuum gauge on it and see if your suspicion is is correct.
TomO | -- 05-03-2018 @ 6:45 AM |
Here is a link to an article on how to interpret the vacuum gauge readings. http://www.secondchancegarage.com/public/186.cfm A compression tester will also detect valves not seating. Tom
shogun1940 | -- 05-03-2018 @ 10:14 AM |
I would look up how to do a leak down test, where you put shop air into a cylinder on tdc and see where the air comes out.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11872 |
