Lobo | -- 04-24-2018 @ 6:49 PM |
I seem to recall a conversation regarding the correct gear lube for the 1936 rear differential. Does anyone have a recommendation on the Gear weight lube. Also anyone have a chart of grease fittings for the 36 Phaeton?
39 Ken | -- 04-25-2018 @ 4:20 AM |
I use CRC 140 GL-4 (NAPA) in the rear. You can also use in the transmission. A lube chart should be in your hand book manual if you have it. Ken
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11849 |
