Christopherq398 | -- 04-23-2018 @ 8:33 PM |
Does anyone have any idea on the value of this engine as it sits?
Christopherq398 | -- 04-23-2018 @ 8:34 PM |
Another picture
Christopherq398 | -- 04-23-2018 @ 8:35 PM |
Another picture
Last one
trjford8 | -- 04-24-2018 @ 6:43 AM |
The motor is a Y block Ford and can be anywhere between a 1954 to 1964. They came in the following configurations; 239 cubic inches, 256 cubic inches, 292 cubic inches, and 312 cubic inches. If you know nothing about this motor it's basically worth scr*p iron prices. It appears to have been sitting for a real long time and you have no idea if was removed due to a cracked block or a number of other mechanical ills. This message was edited by trjford8 on 4-24-18 @ 6:46 AM
cliftford | -- 04-24-2018 @ 7:00 AM |
Of course a picture tells you nothing about the condition. I wouldn't scr*p it. Its bound to have some usable parts on it that some one would want.
woodiewagon46 | -- 04-24-2018 @ 7:08 AM |
Who knows why the motor was removed. Was it just pulled to do a rebuild or was it removed because of un- repairable issues such as a cracked block . Did water get into the motor while it was stored? With out documentation, you are basically gambling!
CharlieStephens | -- 04-24-2018 @ 11:16 AM |
Previous posts have identified it as correctly as could be done from the pictures.Try asking over on HAMB, https://www.jalopyjournal.com/forum/ A few people use them over there. Unless you know a lot more about it you would probably be lucky to find someone to haul it away. From the fact that it has a 2 bbl carb and single exhaust it is probably (bolt on things can be changed) not a 312 cubic inch version, the one that everyone wants. If it is not already in your back yard I would leave it where it is. Charlie Stephens This message was edited by CharlieStephens on 4-24-18 @ 11:27 AM
1934 Ford | -- 04-25-2018 @ 8:37 AM |
Triford8, Was there not a 272 ci V8 in between the 239 & the 292? Maybe 1956-57? 1934 Ford's since 1972
trjford8 | -- 04-26-2018 @ 8:38 AM |
Yes you are correct. There was a 272. Thanks for the reminder. I think they were primarily used in the pickups and other commercial vehicles.
wmsteed | -- 05-08-2018 @ 7:14 PM |
The red valve covers with traces of the Y-Block decals still visible, and a small 2 barrel carb tells me the engine is most likely a '58-59 292 out of a F100-250 truck. As I recall, the earlier Y-Blocks were yellow with black valve covers and the '58-64 292's were black with red valve covers. I did not note a PCV system, and the crank-case breather on the lower left side of the engine denotes that the engine is not a '63-64. In any case, I would say the engine is worth, maybe $100. or less. Bill 36 5 win delx cpe
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11846 |
