artron9 | -- 04-19-2018 @ 4:20 AM |
Thanks to you guys I purchased tailight bulbs from Sacremento Parts. They were a little brighter. I also painted the bulb housing white. Both these things helped. I also replaced the flasher which didnt help at all. You can barely see the lights flashing. Any ideas?
cliftford | -- 04-19-2018 @ 5:18 AM |
Are you talking 6v or 12v? If 6v could you be using a 12v flasher? Do you have a good quality flasher, not a cheap foreign one? The switch might have dirty contacts.
TomO | -- 04-19-2018 @ 6:38 AM |
It sounds like the flasher may have too short of a "on" cycle. This could be due to poor grounding at the bulb or at the flasher, or low voltage at the flasher. I would start by checking for a good ground by using a jumper from the light housing to a bare spot on the frame. If the lights stay on longer, that is your problem. If the ground is good, then I would check the voltage at the bulb with the car running at a fast idle and the stop light switch shorted to get a steady voltage at the bulb. If it is less than 6 volts, you will have to find out where the loss is coming from. Tom
artron9 | -- 04-20-2018 @ 3:05 AM |
Thank you Cliftford and TomO. Iwill start by replacing the flasher with another new one from Napa. I notice that the lights get more intense when I increase the RPMs. Thats how they should be at idle I assume. This is a 6 volt pos grnd sysstem. 52 Crestline.
Drbrown | -- 04-26-2018 @ 10:58 PM |
Beside checking the above mentioned items, and since you notice that the lights get a little brighter when the engine RPM's are above idle, check the voltage output at your voltage regulator. OE type generators typically may be shy on voltage output at idle but a good mechanic can check and may be able to improve the voltage output. Do you notice same when using headlights ?
artron9 | -- 05-01-2018 @ 2:41 AM |
Great point dRbrown! WILL DO THAT!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11831 |
