ken ct. | -- 03-15-2018 @ 12:45 PM |
What is this part,cant find it in Vanpelts or Green Bible ??? ken ct
MG | -- 03-15-2018 @ 1:00 PM |
https://www.oemfordpart.com/oem-parts/ford-shock-absorber-asy-ash12181 or http://www.jegs.com/i/Alloy-USA/013/12181/10002/-1
ken ct. | -- 03-15-2018 @ 4:09 PM |
NO that's not it ,supposed to be a distributor part for FH dist. ken ct thanks for trying. ken ct
MG | -- 03-15-2018 @ 5:55 PM |
Here you go > 1928-1931 Distributor - Washer .045 Thick (Fiber) - NOT A FLATHEAD V8 PART [A-12181] 1928-1931 Distributor - Washer .045 Thick (Fiber) .015" thick fiber washer used to take up play between the shaft sleeve and bottom of distributor housing. http://lbcunited.com/earlyford2/product_info.php/cPath/137/products_id/8687?osCsid=41b911b22ae014b40ed53382b7a28328 This message was edited by MG on 3-15-18 @ 7:06 PM
ken ct. | -- 03-15-2018 @ 10:38 PM |
Thanks MG . Some one on here thought it was a V8 part?? ken ct.
MG | -- 03-16-2018 @ 12:32 PM |
Ken - here's another answer to your query from 'supereal' back in 2014.... https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6916 supereal 01-14-2014 @ 11:39 AM reply profile send p.m. Senior Posts: 6349 Joined: Oct 2009 Don: The cam and weight assembly, called "distributor cam retard" was originally marked 11A-12181 and was obsoleted and replaced by the 11A-12185. That is why both numbers appear on the part. The 12127 refers to the distributor used in the 37-40 cars, and the 39-40 trucks. That weight/cam assembly was also used in the later 21A and 59A distributors. It was Ford's policy to reuse parts across years, but often parts that look alike have subtle differences. The best reference to identify parts, and to learn which were replaced, is the "green book", a master parts manual.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11740 |
