tgs40ford | -- 02-23-2018 @ 12:27 PM |
Ordered overhaul parts to totally rebuild a 1934 6 volt 3 brush generator. Recieved the parts and brushes. I noticed that one brush was much thinner than the other two. Does anyone know in which brush holder the thin brush should be installed? #1Grounded brush--#2 Moveable center brush--#3 or third brush??? This vehicle has a factory installed radio, so it has the larger two coil cutout/ regulator that is oblong shaped. Does anyone know if the newer electronic cutout will work for this application?
cliftford | -- 02-23-2018 @ 7:40 PM |
Check with Van Pelts on both questions.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11689 |
