carcrazy | -- 02-11-2018 @ 2:29 PM |
What is the longitudinal angle of the V8-60 Engine as installed in a 1937 Ford passenger car?
alanwoodieman | -- 02-11-2018 @ 6:29 PM |
carb base plate on manifold will be level
carcrazy | -- 02-11-2018 @ 11:39 PM |
Thank you. I have an extra intake manifold for a V8-60 and when I set the manifold on a level surface and check the carburetor mounting surface, it is also level. This leads me to believe that the engine installed angle must be zero degrees.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11652 |
