TomO | -- 01-22-2018 @ 2:28 PM |
Does anyone know if the reproduction 80# sending unit sold be Dennis Carpenter has internal workings like the original or is it a variable resister like the GM ones? http://dennis-carpenter.com/oil-pressure-sending-unit-80-lb/p/41A-9278/?tab=cars Tom
Drbrown | -- 01-23-2018 @ 7:41 PM |
TomO .... don't know about DC's unit but have a used OE 80 lb off a '47 if you need it. Worked fine when last on an engine. Dan
51f1 | -- 01-25-2018 @ 7:30 AM |
Don't know, but I do know that it shows the oil pressure on my '51 8RT to be 35 psi rather than 50 psi. I have checked the pressure with a mechanical gage, and it is actually 50 psi. My nos gage that gave up the ghost always indicated 50 psi. A second sending unit from Carpenter gave the same results. Carpenter's ad says it's exactly like the original, whatever that means. Richard This message was edited by 51f1 on 1-25-18 @ 7:32 AM
TomO | -- 01-25-2018 @ 12:15 PM |
Thanks ,Dan. I have a couple and need to get out in the garage to test them. I was asking the question to help a guy on another Forum. He bought the NAPA replacement and I am pretty sure that it is the variable resister type as it does not show the correct pressure. Thanks for your information, Richard. Now I will not recommend them. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11588 |
