onedon | -- 01-19-2018 @ 2:40 PM |
I pulled the intake off my '37 just to check it out, been setting 23 years, looks good. Anyway some bolts had washers and some didn't. I know they all should, my question is are they special or can I use some from a good parts store? Anybody know correct size if so Thanks
kubes40 | -- 01-19-2018 @ 4:05 PM |
You should use washers on all aluminum intake manifolds as you know. You can use any that you like to get the job done. Roy Nacewicz sells the correct washers in finish, diameter and thickness. For his price, I'd suggest you simply order them from him. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11568 |
