Shark | -- 01-18-2018 @ 6:53 PM |
im installing the fuzzy strips on my garnish mouldings and wanted to know how to finish the seam. im using original clips. do you use one clip and catch both ends. or two clips one for each end. what do you guys use to cut them. thanks bruce
1937sedandelivery | -- 01-19-2018 @ 10:56 AM |
I believe this part of my 37 is original, please see pics. It shows how the whiskers on the door frame and garnish mouldings are mounted. Two separate clips are used, one on each end of the seam joint, as opposed to sharing a single clip. I can take more pics if you want. Thanks, gregg
Shark | -- 01-19-2018 @ 11:56 AM |
Thank you Gregg. I was going to cut the ends with a side cutter but was afraid the ends would squish and not give me a nice neat seam. I think I will cot them with a dremel tool and file the burr off. Thanks again Bruce
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11565 |
