fordv8j | -- 01-16-2018 @ 2:23 PM |
Working on an 1948 8-n tractor,need to replace pto oil seal on the back, do I need to remove the bearing housing, and if so are there any problem getting it back together
TomO | -- 01-17-2018 @ 7:08 AM |
You may get a better response on one of the Ford tractor forums. There are several forums and one of them should be able to give you a good answer based on experience. Tom
pauls39coupe | -- 01-17-2018 @ 8:36 AM |
Park the tractor with the front end slightly down hill to keep the oil in place. Next you need to remove the 4 bolts holding the PTO, and remove the whole shaft. The seal is held in place with a snap ring. Remove and replace the seal. A thorough explanation can be found in a I&T shop manual #FO-4 which is available at most farm stores like TSC or Family Farm. They are also available on line from YT Tractor who hosts an excellent forum.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11555 |
