FredWJensen107@Gmail.com | -- 01-16-2018 @ 5:22 AM |
Is there a grommet set for the spark plug wire tubes?
3w2 | -- 01-16-2018 @ 5:33 PM |
If you mean for the holes where the individual wires exit en route to the spark plugs, the edges of those holes had zinc 'grommets' to prevent chaffing of the wires. I am unaware of any reproductions of those zinc components. Other than the tapered rubber tubes encasing the spark plug wires between the front ends of the conduits (tubes) and the outer distributor caps, there were no rubber rubber components used. This message was edited by 3w2 on 1-16-18 @ 5:35 PM
FredWJensen107@Gmail.com | -- 01-17-2018 @ 1:07 PM |
Great....My tubes have these....I thought there would be some rubber, but I guess that would only burn. Thanks for your help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11554 |
