V8JR | -- 12-20-2017 @ 6:12 PM |
When installing a Stromberg 97 carburetor what is a good starting point for how many turns out on the idle needle screws? Once running, any tips on fine tuning the idle screws? Thanks - V8JR
ken ct. | -- 12-20-2017 @ 9:19 PM |
7/8 to 1 turn out will get you real close. ken ct.
TomO | -- 12-21-2017 @ 6:49 AM |
To fine tune turn 1 screw 1/4 turn in and check the vacuum reading, if it is higher turn the other screw 1/4 turn in, if it is lower, back off the 1/4 turn and add 1/4 turn out, check the vacuum and if it is higher back off the other screw 1/4 turn. Because the idle mixture screws can affect the other side of the carburetor, what ever you do to one side, do to the other side before making further adjustments. Use your vacuum gauge while adjusting the mixture, to get the highest vacuum at idle. Tom
ibshane | -- 12-21-2017 @ 7:18 PM |
I have installed a PCV valve in my '37 V8/85 When setting the idle mixture using a vacuum gauge do I put the gauge in tandom with the PVC valve or in place of? This message was edited by ibshane on 12-21-17 @ 8:15 PM
TomO | -- 12-22-2017 @ 8:40 AM |
A properly installed PCV valve will not affect the vacuum readings, so either option should work. Tom
V8JR | -- 12-22-2017 @ 9:12 AM |
Thanks guys for the help
ibshane | -- 12-22-2017 @ 12:41 PM |
Thank you!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11498 |
